Message was not delivered to the aggregator preventing add/delete functions
Check for valid LAG instance group ID and membership. If it is valid, try to see if the message is logged once the switch is rebooted.
Warning
Setting the aggregator failed. Group %grpId% not sent, returned with %code%, to aggregator instead of %needed%.
| Name | Type |
| grpId | String |
| code | uInt32 |
| needed | uInt32 |
